My 2003 Chevy Silverado 1500 HD 2WD looks like it never had an adjustment bolt for either of the torsion bars.  Has anyone ever seen or heard of that?  The key with the treaded hole is there, but looks like there was never a bolt in it.  It was like that from factory.
That certainly sounds strange to me. Does it have a lift or is the suspension stock? Does the front end look too low? How does it ride?
Being a 1500 HD, the front end should be similar to stock, but it may have more rake with bigger leafs in the back
Thank you for responding, BigBlock.  My truck is all 100% stock, bought it new.  No mods whatsoever.  It's got 167K miles on it, and luckily only had to replace fuel pump twice and an alternator once.  It's even on its stock brakes!
I never noticed until now that there are no adjustment bolts in place for the torsion bars.  The front is slightly lower than the rear, but it doesn't look abnormal. And it rides pretty stiff, but not too uncomfortably.  I am actually finally replacing all the front-end suspension components - Pitman Arm, Idler Arm, Upper Control Arms, Lower Ball Joints, and Inner & outer tie rods, that's when I noticed there were no bolts there for the torsion bars.  But once all that is done, I will be getting an alignment, so I will be interested in what they say about it. Thanks again!
Edited by Rocko973
Well again it sounds strange to me, but since your the original owner, you know your truck. The missing bolt is curious, but if the ride height is about right and she rides nicely, then without the bolts is just fine. If you wanted to level the truck, adding bolts could be a cost effective way to do it as long as it doesn't stiffen the ride up too much. Gotta be careful with adjusting those torsion bars. Ive honestly never had my hands on a 1500 HD model as they are much more uncommon, so I cant speak for certain here.
Yeah, seemed a little odd to me too, that's why I was asking the question here.  I wonder if Chevy forgot, or just decided it didn't need them.  Thanks again for sharing your perspective.
Someone removed the key bolts maybe stolen but regardless you will need them before an alignment can be done. Buy some new bolts and clean threads in the keys with a tap and install before you go to the alignment shop. Make sure the tech know of the situation so he can adjust "Z" height.
Thanks, redvett!  Good point you make about getting those bolts before going to the alignment shop. I'll order some ASAP.
I suppose someone could have easily stolen mine since they're easily accessible, just seems like an odd thing someone would steal. But then again, people steal all sorts of things all the time, so I wouldn't be surprised.
Yea, those should definitely be there.  I would imagine they were at some point.
They will be needed to properly set alignment on the torsion bar IFS as they are used to set the Z height of the truck before adjusting the caster, camber and toe.
Edited by newdude
Thanks, newdude!  That is good information!  All the responses here were exactly what I was looking and hoping for.
Folks like you, bigblockburban4, redvett, and many others like you are what makes this forum so incredible.  I will definitely do my best to help out others too in anyway I can, but I really appreciate all your responses.  If I come across anything interesting, useful, or unusual regarding my current work on my truck's suspension/alignment, I'll be sure to share it here. Thanks so much!
I definitely agree with the others, I didn't even think about z height for alignment. So I agree, get some bolts, chase those threads, and install them. Put them in with little tension if you don't have a torsion key compressor, take it to the alignment shop and make sure they know the situation. Looks like a problem solved to me
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
    • The average lifespan of automobiles on the road is increasing - here's why
    • Typically it is the Torque Converter, I have a 2.7L Trail Boss and between 25-65 MPH at 1300-1500 rpms under light throttle it has a shudder which I almost consider and bobble or a gargle sound. They replaced my TC but it did not help any, others say it has fixed their issues. It has been back twice now with no fix after.
