Was hoping to get some insight on this. Electrical just isn't my thing.
Rebuild top end, head gasket, graphite, failure due to corrosion
Never had an oiled air filter
Cleaned MAF with alcohol, 99%, spray, never touched
Cleaned TB, TPS seems fine
Idle 630rpm, scanner
Scanner also shows everything else seems to be fine or is at least registering a signal.  MAF is 0g/s
Ground wires all cleaned
1.5 volts to MAF on black and tan while running
632ohms on those pins on the MAF
2002 sierra 4.8L with 360k km, truck ran fine before
Checked continuity to ground, black and black/white are both connected to ground
What am I missing?
Edited by 10 under
Made a mistake, additional information
    Markey
    Markey
  • Who's Online   3 Members, 0 Anonymous, 2,014 Guests (See full list)
