Got it. I sent him this response and imma wait to see what he says lol thanks. If anything do you know the common place for an immobilizer?
For starters, I'll suggest to stop jumping vehicles off. I've seen so many Engine Control Modules get fried by jumpstarting. Just charge the battery for a bit (30-60 mins is usually long enough @ at least 15A). I know it's inconvenient, but life sucks sometimes. We'll hope you got lucky.
Try just turning the key on (second key position, where all the dash lights come on) for about an hour. This should reset the factory immobilizer that hopefully is what was triggered and has shut down the fuel injectors. You'll likely need to hook up a battery charger while this is going on, or your battery will probably die before an hour goes by. After an hour, turn it off, and try to start it.
5 hours ago, Snowcamo said:
Look up under the dash and disconnect the aftermarket GPS locator from the ODB2 port. Then put it in the glove box. The dealership you got the truck from likely disabled your truck.
"...the ECM which will prevent the vehicle starter and fuel pump from operating."
The starter cranking rules out the factory immobilizer.
Pull the cover below the steering wheel off and take a picture of what's there.  Post it. It may be something someone can point out.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 501 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
