Hey all, I’m new here but in searching the web I found these forums to be best for help troubleshooting on the fly.
here’s the deal: I’m out of town for work. Drove a few hundred miles the other day and truck seemed ok. Today went to leave hotel and on acceleration the truck is making a “whooshing” noise then when trying to decelerate it makes whooshing noise again and holds a high idle. Then will calm down. SES light came on. I have a cheap-o scan tool handy but apparently it won’t read my truck. So I contacted on star and they gave me these codes:
P0113
P05AE
P227B
P227D
ive quickly inspected both intercooler boots thinking one may have popped off. No such luck. Any help to get me going again here would be fantastic. I’ve gotta be on jobsite bright and early tomorrow am.
thank you!!!
  • 4 months later...
any update to this? I have the code P05AE currently and also have the same turbo into noise. I also checked my IC piping this a clamp let go. My code reader won't say what the code is, but googling says its lower louver error?any update to this? I have the code P05AE currently and also have the same turbo into noise. I also checked my IC piping this a clamp let go. My code reader won't say what the code is, but googling says its lower louver error?
    Sothpaw27
    Sothpaw27
  • Who's Online   6 Members, 0 Anonymous, 563 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
