Inspired by Darth's post here:
I am going to try and retrofit my 2016 2500 LT Silverado with auto air.  Using Rock Auto for parts and The Body Builders service manual I came up with these notes and some questions for anyone that has done this:
Presumptions:
X1 and X4 connectors are absent and we need sun sensor, upper left temp sensor, and lower left temp sensor.
According to Rock Auto:
  There are two versions of HVAC for the 2016 Silverado 2500.  The C67 (manual) and CJ2 (auto).
Control Module
The part number for the manual Control module is 1574848 and it's lacking the J1 connector in the picture.
The automatic version is 1574531 and it has all 4 connectors (J1-J4) pinned out.
Instrument Panel
There are several versions of the Instrument Panel for C67, but only one version of the CJ2 which is 1574881
Air Duct Temp Sensor(s)
The CJ2 instrument panel air duct temp sensor, front. is 1551332.  Should need two of these upper and lower I am guessing.  Wire color is blue and black/yellow
Pins are
Left Upper BU to X3-1, Bk/YE to ground X3-9.
Left Lower X4-11 (shows Green...but must be Blue), BK/YE to ground X3-9
The wiring diagrams on 246 and 254 show the sensors are there on both versions, but the diagram on Page 479 showing the sensor location labels them as CJ2.
Considering they are on connector X4 which doesn't exist...I imagine that's a typo in the diagram.
Sun Sensor
There are two versions of the sun sensor.  C67 is 13525289 and CJ2 13525291.  .  They look identical but CJ2 version definitely has more pins.
Sun Sensor wiring shows 3 new wires needed to the control module X1 Connector
X1-4 BU/WH to Pin 3 of sensor
X1-14 YE/VT to Pin 4 of sensor
X1-13 YE/VT to Pin 4 of Sensor
X1-20 GY to Pin 2 of Sensor
Other Notes:
X4 connector also has a new actuator for M6L air temperature door actuator left in CJ2 version.  Presumably for Sync...since this is located under the dash (is it?), I am skipping this.
The X4 Connector on page 947 is showing (CJ2) by it's name, X1 on page 944 is not showing (CJ2) and has some wires on  18 & 19 (Lower Air Temperature Sensor).  Can't find anything on these.
My questions before I get started:
The X1 Connector on Page 944 shows X1-18&19 pins as Upper Air and Lower temp sensor.  WTF are these and do I have an X1 connector?  Sure seems like it's there in all diagrams.
Does the wiring harness plug already have the extra pins needed for the Sun Sensor?  If so, where do the wires stop? If not, how did you add them?
Are there holes there for the temp sensors?   How do you get access to them?
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
    • I'm well aware of the typical bathtub failure curve, but plotted, this truck has been more like an elevated straight line.  It started days off the lot with misfires that GM couldn't solve for almost 2 years, and steadily continued over the last 5 years with repeat replacements of wiring harnesses, camera modules, cameras, parking sensors, head unit, rear windows, rear leaf springs and bushings, lower control arms, a radiator, and now an ac compressor and a column shift assembly.
