This isn't really a mod as much as it's an adaptation from my GMC Sierra 1500 SLE's I've had to my GMC Sierra 2500HD AT4.
The boards I took out of my 1500 are about 8" to short. Also, the slots are not spaced the same so I cut new boards to fit and added a 3.5" offset to the boards near the tailgate so my coolers, water jugs, etc. fit going to camp.
One is a 2x8 with eye bolts for using bungees and the other is a 2x4 to keep the wooden boxes in place if I don't need the 2x8 and can get the Jet Sled over it with a deer in it. I used two 1x deck boards for the spacer along with 5/16 carriage bolts, washers, lock washers and double nuts. The wood boxes are 48" long, the space between the boards is 48.5". I keep a jack, other tool boxes and bags, etc between the other board (2x3 and the cab.
It's kind of tricky getting the 2x8 in and out but I don't swap them to often. Usually keep the 2x8 in for securing gas cans when not going to camp.
Edited by rjgvt
I made a 45 degree cut on the bottom corners 1/2" x 1/2" so the boards sit on the bed.
Nice mods.  I bought a cargo bar for mine to keep things like Jerry cans from sliding all over.  When I had an F150, I had their bed extender/cargo container or whatever.  It was quite clever, could be folded in or out or stowed very easily.  Wish GM had something similar.
    xdieselmechanic
    xdieselmechanic
  • Who's Online   2 Members, 0 Anonymous, 614 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
