I'm thinking of replacing my stock wheels on '23 LTZ with the same style but chrome. I looked on the GM accessories page and didn't see any. I came across these and wondered if they were direct replacement and if anyone had experience with this brand.
Replica 176C Snowflake 20x9 6x5.5" +24mm Chrome Wheel Rim 20" Inch | eBay
23 hours ago, luke1333 said:
FYI GM part # is 84799392
Is that the part number for the GM wheels I have on my LTZ ?
You know, you could just copy and paste that number into google to answer that question.
PS: that part number is for 22's and not 20's.
Edited by CamGTP
Yes I know.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
