Anyone know what pinout is on the e78 ecm on a 2015 silverado 2500 6.0 for flex fuel.  I wanna add the flex fuel sensor and disable the ecm virtual one.  Truck is a flex fuel truck.  or does anyone know of a kit with the sensor and pigtail?
Looking for insight.  2015 6.0 just did a whipple.  Only does it when giving more than 50% throttle.   Having issues and trying to figure it out.  Heading back to tuner for 3rd time next week.  Sent him this from another group  Dirk Diggla doesn't look to be a convertor issue, especially if Temps are still normal. Every convertor failure I've seen,, the 1st warning signs are 6th gear shudder and higher than normal temls from slippage,    id be intersted in seeing what was done to the VTT tables and reported torque tables in your tune. These gen 5  E78 pcms are 100% torque based and if those 2 tables aren't done correctly cause lots of issues. I'm betting your tune is way off  His reply Hey Andrew, I’m m not sure what that noise could mean, I read what you sent that you found online, but the VVT tables are stock and untouched, the TW tables were raised in the correct areas, I was able see the video I’m not sure what that noise is..   Looking for insight.  Know its hard without a log file to view.  https://drive.google.com/file/d/1LU5kRrMpe3SMn9BuDwLNnwUyqM3NDdys/view?usp=drivesdk
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 395 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
