I have an 02 Silverado 2500HD and i keep on having transmission fluid over heating issues, i had the transmission replaced once and after driving truck for 18-25 miles i would get a warning light saying the transmission fluid is hot, i was told i might have my lines dirty, i flushed them, tested the truck, same issue, i was told to replace transmission cooler, did that, retested, same issue, i replaced the radiator as-well and same issue, we went as far as to replace the transmission one more time and i re tested last night and once again im having the same issue, i started to think the transmission might not be overheating and it might be just a bad reading but its 2 transmission now so i have no clue now, ** note , my original transmission blew because of low atf and i did get the same Trans hot message before it completely stopped working, i was thinking maybe it stayed in the system but im not sure, does anyone have an idea what it can be? Id greatly appreciate any feedback, thanks
Yes, this is an important. I would suspect wiring concerns with a shorted temp sensor circuit causing this condition. Do you have the 8.1/ Allison combo or the 4L80?
