Was having ac issues
Replaced compressor (new gm genuine)
Found leaks in 2 o rings, I replaced all o rings
Vacuumed and found no more leaks
Charged system and all is well with compressor
Only issue is the fans will not turn on when I turn on the ac.
I tested the fans on all speeds using my autel scanner (dealer grade scanner)
And both fans work perfect.
Also found corrosion on the back plug connector (not the plug nearer to the top that you can see) to the ac pump, so I stripped the wires and soldered them directly to ac compressor. Not sure what that plug is used for so not sure if a bad connection may be the issue but I'm certain the connection is good.
Assuming connections and everything else is fine, what steps would I take to find out why the fans won't spin with ac on?
