I'm struggling with a ton of lost connection codes, and modules that are not reachable. The modules that cannot be accessed (scanner says they don't exist) is the airbag and chassis control module. Some of the codes which show up are:
U1510 - Lost communication with device on LIN bus
U18A2 - Lost communication with fuel pump driver control module
U0422 - Invalid Data Recieved from Body Control Module
U0137 - Lost communication with Chassis Control Module - Auxiliary
U0151 - Lost communication with Inflatable Retraint Sensing and Diagnostic Module
P2537 - Ignition Accesory Switch Circuit Low Voltage
U0415 - Invalid Data Received From Electronic Brake Control Module
U1556 - Lost Communication with Device on LIN Bus
Also many short to battery codes on light circuits on the BCM
Additional symptoms are radio screen off, AC not cold, remote start doesn't work.
I checked the dash G218 grounds and the battery ground to the frame and all seemed good. Battery voltage is over 14V. I'm thinking potentially a bad BCM, or a bad battery ground strap. Those are the last 2 things that I can think to check before taking it to the stealership
Any help is appreciated. Thanks!
Check out the South Main auto Youtube page. He tackles a lot of these types of electrical issues. Theres a 2019 Silverado video that has similar symptoms to yours and it was the chassis ground on the right side frame/firewall area.
If would try to find an independent shop if you still need to take it in. The dealer can sometimes be a moneypit and they dont always have techs with good diagnostic skills.
Battery positive and negative cables are notorious on this gen truck, especially the short positive off the battery.
Thanks! I checked that ground and no luck, but I'll go ahead and check the remainder of the grounds on the truck
I'm leaning towards one of these being the issue as well, as well as the battery potentially. Previous owner said the battery was changed last october but you never know...
For that short positive off the battery would it be worthwhile to change the whole fuse block along with that short cable?
Up to you.  GM used to only sell the cable as part of that block but they now sell it both ways, the block w/cable or just the cable.
  • 1 year later...
  • 3 weeks later...
Did you ever find out the source of your issue with the multiple errors on your truck ? To the original poster question anything would help, I have similar issues also can bus A off throttle response chassis control module, loosing connection with ECU ecm TCM. If you or someone has any answers. All grounds have been cleaned removed fuse block cleaned and reinstalled finally did some scan but not alot to go on. Thanks DJ
    1981dustin
    1981dustin
  • Who's Online   5 Members, 0 Anonymous, 1,645 Guests (See full list)
