have a 14 chevy silverado 5.3 LT got code p066d for oil pressure selonid off was told it was my oil pump, well after a 20 hours job i change my oil pump, oil pressure sensor, timing chain and gears added all new filter and oil. started truck up code went away but now my oil pressure is low again. at cold start 40-50 psi and warm 30 psi, once she gets to 210 and drive it when i come to a stop or at idle shes at 16-19 psi i now this is TO LOW for chevy it states atleast 22 psi which i dont have. What could this be? i aslo change the screen in the pressure sensor too so what could be left. NO noise at at not tick everthing else is fine. I did my lifters in 2022.
Do a 'test block' pressure test. Don't rely on the dash gauge. Start there and see where you land. Here are your targets. Compare to the dash for reference but don't rely on it.
Hot oil pressure minimums.
22 psi @ 1,000 rpm
30 psi @ 2,000 rpm
33 psi @ 3,000 rpm
LV1, LV3, L83, L86 and L96.
We placed a manual Guage on it and at cold start she's 40 to 50 and warm she's at 30 at temp 210 at idle she's 16-18 that's where it's to low. After she warms up it has gotten as low at 10.
Gm states at warm idle the lowest she can be is 22 psi I'm at 10 to 18 at warm temp 210.
How many miles are on this truck? Is the bearing clearance too large from wear? Connecting rod side clearance too large,cam bearings worn out?
Edited by mjm-1957
188 thousand miles had the lifter done last year and they stated no issuse with bearing or cam...
What I posted if from @newdude, a GM tech, a few years ago. No mention I can find of a minimum pressure at idle. But 10 psi per thousand is a normal benchmark. Lowest test pressure is at 1K rpm. Why? Because 22 psi is the minimum required to latch the AFM lifters and that can never happen at idle. About 1200 rpm is the lowest the AFM even tries to work. IF you can hit those test pressures at those rpms at full temp your idle pressure is fine.
may have an issue with the VLOM (valley lifter oil manifold), that's where the oil goes to control the AFM, also does this L83 have a vane type oil pump or gear type? (gear type requires alignment). Anyway, I did a AFM/DOD delete on my L83 and modified the VLOM by removing the oil solenoids and forgot to (actually didn't realize) plug the oil galley going to the oil solenoids which'd caused low oil pressure at temp., but after I plugged the port then oil press. was good. So check that for leaks or oil drainage.
Hey man did you ever figure this out? My truck is doing the same thing… low oil pressure at idle after engine reaches temp, 10 psi on the gauge. I replaced the oil pressure sensor and filter screen too…
    daveishi
    daveishi
  • Who's Online   2 Members, 0 Anonymous, 1,063 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
