I have a 2020 GMC Sierra that has 80,000 miles. Would it be possible to swap the driver seat bottom and the back portion to the passenger side and visa versa while keeping the controls where they are (the plastic base part) so that I have a new driver seat
NO. The side airbag is in the seatback so you can't swap those. It's potentially possible to swap the bottom foam, but it's a huge hassle. You're better off finding a local late model salvage yard and get a low mile take out if your seat is that worn out.
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 256 Guests (See full list)
