2020 RST
What needs to be added, hardware-wise to use my newly acquired camera in the LTZ grille I bought?
I believe i have the IOR radio system. 8" screen, non navigation.
Have done Google searches, and searches here also. Some info found. But wondered if anything new has came up.
On 8/10/2024 at 9:31 PM, jashaw said:
2020 RST
IOR is the 7 inch radio.
VPMs work with the IOS and IOt 8 inch radio, so you will likely need a new radio screen and possibly the radio as well, you will also need a video processing module, all the other cameras as there will be image faults if you don't, and then all the wiring for all the cameras.
There are 8" IOR Variants out there as well just to muddy the waters even further. Unfortunately the IOR doesnt have any provisions for extra cameras sadly.
On 8/10/2024 at 6:31 PM, jashaw said:
2020 RST
Post up a pic with all the lights on...........😀
I'll have to scan the QR code on my door. To see the exact radio I have.
I'll have to scan the QR code on my door to see the exact radio I have. If it's too expensive to do, which it sounds like it may be if I need all of the hardware and software programming done. Just thought since I bought a grille with the camera, i'd put it to use.
20240711_194807.thumb.jpg.8cf14db425ab5b399f2e4567821559f5.jpg20240711_194807.thumb.jpg.8cf14db425ab5b399f2e4567821559f5.jpg20240711_194807.thumb.jpg.8cf14db425ab5b399f2e4567821559f5.jpg20240711_194807.thumb.jpg.8cf14db425ab5b399f2e4567821559f5.jpg20240711_194807.thumb.jpg.8cf14db425ab5b399f2e4567821559f5.jpg
Easy half mile of useable light. All triggered with relays by the high beam.
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,375 Guests (See full list)
