I have an 07 Tahoe that has been giving me nightmares. I had a number 8 misfire I could not Trace down so I replaced the camshaft. After replacing the camshaft I had a number one misfire that I still cannot Trace down. I have replaced the head, lifters, rods, injectors,spark plugs, ignition modules plugs and wires compression tested it, and checked for vacuum leaks, everything is good I am getting fuel I am getting fire I am getting compression. I am wondering could this be an issue with my crankshaft sensor. Or any other ideas are welcome. It does misfire worse under load.
  • Sad 1
I have an 07 Chevy Tahoe with four wheel drive. I had a number 8 cylinder misfire. I could not trace it down and replace the camshaft thinking the lobe was bad. After replacing the camshaft now I have a number one cylinder misfire that I cannot Trace down. I have replaced the head, lifters, rods, rockers, injectors, ignition modules, spark plugs and wires, and the camshaft position sensor. This misfire occurs randomly at idle enough to set off the code but it is worse under load. I have fuel I have fire I have good compression. I am half tempted to switch out the crankshaft position sensor. I don't know if the computer would cause a single cylinder misfire so any input or ideas would be very welcome.
  • Sad 1
  • 2 months later...
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
