Bigger tires+10 bolt rearend
Well, I've been saving my $$ and almost have enough to get either the 35" X-terrain's or the 36" STS Radials. Just wondering if the rearend will hold up with these larger tires? Also, any problems with the front diff possibly? The 35's will fit with no problems, but the 36x14.50's are going to need some air dam and bumper trimming. Thanks, Chris
A 1997 GM Truck will have come with stock 30 inch dia tires, so going to 35" or 36" tires will be about 20% larger.
That means the diff ratio will change by about 20%, meaning all things that count tire rev's will be off by about 20%. Speedo, tranny computer, ABS computer, etc.
Also means the brake lever arm has been effectively reduced by about 20%.
You'll need to change your diff ratio to higher numeric ratio by about 20% to keep things close to what they were.
Nothing can be done with the brakes other than to go to Praise Dyno Brake pads/shoes or to larger dia rotors (which will require larger dia wheels).
Then the known weakness of a 10 bolt and it's JB5 rear brakes. Better to consider 12 bolt (and the JB6 drum brakes) or even 14 bolt (this is an 8 lug wheel...though there are some 6 lug on the "small" 14 bolt semi floater).
My truck already has 4.10's put in. As well as a Superlift Truspeed Calibrator to get the speedo, ABS, Shift points all in line with the change in gearing and bigger tires that I now have. The Truspeed is adjustable, so that won't be a problem. But the rearend will have to stay the same. Not worth it to me to change it considering I'll be getting a D/A CC GMC truck around '06-'07. The truck originally had 3.42's. Any other thoughts? Chris
Not to say yours doesn't work right, but if you put the settings at a 35" tire, then you'll be off to start with. BFG 315's aren't a true 35" tire, they're a little less. My tires aren't a true 33", they are 32.6 or something. I got mine dialed in perfect with my GPS. At what speed are you off by 5mph? I can't be throughout the range, since it's percentage you are off. If you are off 5mph at 65mph, it would be off by like 1.5mph at 20mph, not bad. Try to adjust it some more, you should be able to get it as close a 1% off. Maybe you got a bad unit? Chris
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
