One of the things i disliked about this truck from day 1 was my fingerprints all over the screen and how hard to was the keep the piano black trim clean.  Well not much you can do about the latter but I bought screen protectors from Screen ProTech and installed the 3 piece setup on my truck. They are supposed to fix the fingerprint issue. I was not planning on doing the gauge cluster (2  additional pieces) but had to order it that way as they only sell a kit with the 3 pieces.  Doing the cluster looked like a hassle but I did it anyway and it turned out to be super easy.
The kit comes with all the tools and solution you need to install the 3 pieces and if you choose the "insurance" option which cost a little more they will send you two of everything in case you screw up.
I am impressed. I went with the gloss and looks factory. They also have matte finish if you have glare issues. Dont have smeared fingerprints all over the screen like I did.
Two thumbs up for me.
https://screenprotech.com/
I just put one on mine but have been looking for one for my wife's 24 Subaru Ascent....the anti-glare version, this is the one. Thanks.
After having it for a couple weeks there is no going back for me.  It looks better than new and stays so much cleaner.
They sell a set for the outside pillars. I am considering doing those as well as the black seems to show love marks super easy.
    RichardRS
    RichardRS
  • Who's Online   3 Members, 0 Anonymous, 836 Guests (See full list)
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
