I need some help. I have a used Blue and White 50W (about 40W actually) that I just bought second hand. I recently started seeing the alert LED on the stepper motor driver when aligning mirrors and doing test cuts (sometimes only one axis, sometimes both, sometimes no alert).
I looked in the manual for the stepper motor driver and the LED alert indicates the following: An error occurs when the motor coil current exceeds the current limit of the driver.
Can someone explain what this means and if it is software or hardware related?
