My truck has no manual entry tailgate, not the 3 part tailgate either.  Is there a way to shut off the inside chime and the external buzzer when opening????
on hunting trips it's impossible to access gear in the back without alerting everything within a 1/4 mile radius
in vehicle settings it only allows the chimed setting to go down to 50%
This annoys the absolute $hit out of me too.  Hopefully there is a fix to turn it off.
So you have the power up/power down tailgate?
2 hours ago, mgrun said:
Yes, power up and power down, with an annoying chime each time
As far as the door chime inside the truck when you open it, you won't be able to do anything there.
As for the beeping at the gate itself, whatever component is creating the audible beep, perhaps it can be disabled by cutting a wire or something?
There is no specific speaker there that I can tell, so its either the motor or the tailgate module that is emanating the beep with some sort of internal speaker.  Looking at the schematics though, there isn't a "speaker" wire or tone wire, so my only guess is its triggered by the logic in the module or motor and the tone is coming from inside one of those components.
Edited by newdude
Is there an external noise?  I thought when I opened the tailgate the only sound was from the inside chime. Maybe I need to pay more attention.
Is there anyone that can hook up to this truck and turn the chime down via reprogram????
mine makes some kind of buzz sometimes from the tailgate I think.  Makes so many damn noises it makes it almost impossible to drive on a hunting trip.
ill see if I can video the noise
There's a beep when the gate is in motion.  Comes from one of the components in the tailgate itself but nothing indicates in the schematics or the description and operation as to where that beep emits.
I'm seriously considering accessing the tailgate and start unplugging things.  I'm out hunting right now, and this morning and dropped the tailgate on the road before the property so I didn't scare anything and my backpack fell out on a bump while driving in.  Had to walk 1/2 mile looking for it.
i can't believe there isn't a software update we couldn't press GM to do!  What the heck is the point of both noise makers??????  In the cab and on the gate?  At least write code to turn the chime down when opening, and then cut that stupid buzzer when accessing the tailgate
The chimes are part of FMVSS standards from the best of my research aka they are required to have them per Uncle Sam.
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 3,061 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
