Selling tires
I just ordered a set of 2004 alloy rims for my 97 Z71, and I am going to take the firestones off of the 2004s and put them on the 1997s, plus I am taking my spare, which is a real spare 265/70/16 Wrangler RTS off its rim and selling it. I was wondering what a good price would be to ask for the rims and tires and the spare
Ok Gonna offer the stuff here first and if no takers I'm headed for e-bay. I have a set of 4 stock 1997 GMC Sierra rims, with a very slightly used set of Firestones 265/70/16s on them. I had them professionally mounted and balanced today. I live in the North Louisiana Area and will deliver local or work out shipping with you. I'm asking 300 bucks for the set. If interested my e-mail address is [email protected]
