JDC85 Posted December 8, 2024 Posted December 8, 2024 I have a parasitic draw on my truck when I put a scanner these codes appeared. I thought it was the ABS however, when I unplugged the fuse the next morning the truck was dead again. During troubleshooting near the battery, I did notice a like something was still on not sure what’s in that area. Any ideas? any suggestion on common parts that normally cause a parasitic draw on this your truck. Thank you in advance
mikeyk101 Posted December 9, 2024 Posted December 9, 2024 This service bulletin covers 2 of your codes and might point you in the right direction. MC-10154263-9999.pdf
mikeyk101 Posted December 9, 2024 Posted December 9, 2024 Check here too as the P0700 could be related to the P0561 https://www.obd-codes.com/p0561 And another thing that is common and repeated over and over here is check all your grounds. These trucks are known for ground problems. And don't overlook the battery failing. The more electronics get added over the years, the more sensitive they are to older failing batteries.
Register a new accountSign in
