Yesterday we had our Christmas adult gathering. Brothers, sister, mother and  spouses. After the exciting ailment conversations my brother laughed reminding us of past conversations. Usually who has the fastest vehicle. Taking that theme I asked my brother about his F-150 Super Snake as far as the fastest at the shop. Many years it was my modified 92 Chevy that I picked up off eBay for 7500$. As it turns out it’s not. There’s a TRX, a Raptor R and the winner is. A regular cab F-150 4x4 with the Roush supercharger package. All put together by our local Ford dealership with warranty. No ridiculous badges that attract attention. It looks like a regular Ford. About half the cost. He didn’t learn anything from me.
