Looks like the 2025 GM trucks and SUVs equipped with the 6.2 can now get the cold air intake that they discontinued I think in 2021.
It was only discontinued as an over the counter accessory.  Its been available this whole time as an LPO performance package on 6.2s.
Good to know.
  1. Performance Enhancement: traffic rally
    • The GM cold air intake is designed to increase airflow to the engine, which can improve horsepower and torque.
    • By allowing cooler air to enter the engine, it enhances combustion efficiency.
  2. Sound Improvement:
    • Cold air intakes often produce a more aggressive engine sound, which many enthusiasts find appealing.
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   3 Members, 0 Anonymous, 4,952 Guests (See full list)
