Need quick help from you guys!!!!!!!
Hey guys,
I will try to make this short.
I ordered a 2 map light upgrade pod for my '04 silverado from JP customs. It turns the dome lamp into a dome lap with 2 map lights. Anyway, I had to take down my front overhead console to wire in the power wire for the new dome light and I got it wired in and its blown a fuse somewhere!! My homelink doesnt work nor do any of my dome lights. My map lights on the overhead console still work but thats it. Also, my cargo light on my instrument is on light the button is pressed but the light in the back isnt on. I have looked for the fuse but cant find it. If anybody has an idea please post or call me. My number is below. I am asking ya'lls help. I am leaving in a little bit and need this stuff on my trip for tonight. Please help!!!
Thanks,
Chad
(256)996-2028
Nevermind, Jason at JP Customs called me back. Great guy!! I got everything worked out!!! JpCustoms= :rolleyes::fume:
Yep, Jason hooked me up with some wiring instructions and pigtails that the shop used to do my aux. fogs and aux rears. Always helpful.
  • 3 years later...
