I have about 1500 miles on my new 2024 silverado LT with the 5.3 L engine.  I changed the oil and filter out last week at around 1200 miles just to be safe and make sure that everything is nice and clean.
Yesterday afternoon on the way home I noticed that while parked and the truck was at idle, the oil pressure gauge (slider, not a needle) was reading considerably below the half way point.  I saw no oil drips or anything else like that , so I put it in drive and continued on my way home.  The oil gauge increased the pressure reading to a bit over 1/2 way, which is what I have been seeing/noticing since day 1.  When I got home, I pulled it into the shop and sure enough when in park and at idle, it dropped super low again.  I checked my dipstick and it was fine.  I crawled underneath and saw no signs of a leak from the filter or the drainplug.
I read that some of these engines have a variable speed oil pump.  My previous 2014 5.3L never had a fluctuating oil pressure like this.
Is this something I need to investigate further? Still warrantied, should I make a service appointment? I hate to do that since the nearest dealership is nearly 2 hours away.
Normal and I guarantee your 2014 was the same exact way as its the same style oil pump.
Its a dual stage displacement oil pump.  Hot idle expect 20-28psi, anything under 3500rpm and just normal driving they make about 40psi, anything over 3500rpm it hits the second stage and will make 55-75psi.
I had a 2018, same engine as your 2014 and they have the same exact style pump as a 2019-2024.  Gauge operated the same way but they were the older needle style gauges and not the digital sliding bar.
Great, thank you.  I probably just never noticed in in my previous ride, or, I just forgot. I was looking for any 'problems' associated with the oiling system/pump failures and they are pretty few and far between.
I don`t believe the L84`s have the dual stage pump like the L83`s. I don`t believe they have the piston sprayers either. All the rest of the LT engines have the dual stage and sprayers.
That being said, you`re good to go. I have 5w30 in my new L84. Mine goes down to your observed points too, or a tad higher. I observed carefully when I still had 0w20 and now with 5w30. when hot. Welcome to 0w20 oil and heat.
    250.3k
    RobbertClaus
    RobbertClaus
  • Who's Online   5 Members, 0 Anonymous, 517 Guests (See full list)
    • No I didn’t watch a video of a person who analyzes oil for a living explain general oil usage. For clarity I did ask my brothers one who runs our equipment business. The other who runs our old ROW business about oil usage. Nothing has changed since I retired. Their personal vehicles or work vehicles use no oil. Not enough to see on the oil checking device. Then I pondered. I like to ponder. In this extended oil changing world with oil change countdowns or lights. If engines used say a qt every 2500 miles or up to even 4000 miles. With oil changes reaching as high as 15000 miles. Normal for most people is eight to ten. Vehicles should potentially be seizing up all over the place. Especially in hilly terrain. Just how many people actually check their oil? Maybe 10 percent. Those are the people that probably change their oil early. I like to research used car listings. I have five favorite dealers I check. They all list carfax with their listing. It’s rare to see vehicles with anything but extended oil changes. Transmission service, forget about it. I’ve seen Honda and Toyota certified vehicles up to 100K miles and ten years old. With nothing but normal maintenance. Isn’t nice we all have different experiences and believe our way is the best. You certainly get backup for whatever you believe. Life would be boring otherwise.
    • Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
    • There are a few good takeaways in that video that pertain to this thread, certainly the possibility of the oil control rings having buildup, the fuel injectors and how clean or not that they are ending up affecting the pistons rings carbon buildup, and the fact that its normal up to a point for a given engine to use some oil, and that the oil quality that is being utilized is part of that ring clogging up issue as well.   I was talking with a neighbor yesterday who has a baby LZ0 duramax and he had bought it slightly used but it does consume some oil and he has switched over to 5W-30 Euro spec oil and in this case that never made a difference in consumption over the factory 0W-20 recommendation. He finds it uses a quart in about 3500 miles and as he goes a ways over that distance he adds oil to full and goes another 1000 miles or so and then changes oil and is typically at 40% or so left on the oil monitor at that point with his use case of quite a lot of highway miles and more limited in short run use. I don't know what other LZ0 engines are doing for oil consumption but that is what his is doing.
    • I dont care what Lake says. Goodnight.
    • Ok well I guess Lake disagrees with me on a few points. I call oil consumption pretty basic. Rudimentary. He calls it "really complicated." I think 1qt consumed in 3k miles is a lot. He says that's normal. In 22 minutes, he'll use his natural talent to explain oil consumption to anyone watching this video. He covers everything from obvious engine damage to how normally functioning healthy engines consume oil by design. Lake explicitly states how you drive will impact oil consumption.   Shut up and watch:
