Looking to replace the jumpseat console in my Brother in laws 24 custom with a full floor console from a 2019. Im almost positive the bolt patterns are the same, i just want to make sure the wiring harness is correct. He does not have the "newer" style gauge cluster or radio.
TIA
TIA
Yes the console will fit. No a custom does not have the wiring harness under the passengers side seat for the console. You will need to hard wire the used console into a 2024 custom. It can be done.
  • Thanks 1
There has to be some kind of wiring harness there since he has the jumpseat console with the usb ports in the rear.
You know I cannot answer that question. This is going to get complicated. I have done 2 full console installs in Trail Boss Customs a 2021 and a 2023 refresh. Neither truck had rear USB ports behind the jump seat. The 2023 refresh had like a 2 wire harness for the keyless push button start sensor. No wiring for rear cig lighter, USBs or interior console light. I had to hardwire these circuits and 2 grounds for redundancy.
The back panel from the newer consoles fits the old ones with the trimming of 2 tabs. Then you can reuse the rear seat USB ports from the jump seat and not need to rewire anything.
    1981dustin
    1981dustin
  • Who's Online   4 Members, 0 Anonymous, 1,598 Guests (See full list)
