Looking for an old 6L80 transmission cooler bypass valve with quick connect fittings.
Hi, as the title mentions, I am looking to see if anyone has one of the old 6L80 transmission cooler bypass valve with quick connect fittings for a Silverado/Sierra from a 2014/15 they would be will to sell. Let me know what you have.
