Skid plate pkg good? Or aftermarket.
Do you like the stock skidplates?
I'm going to go look at them today. I'd rather not have too much in the way of maintenance areas. Also, I'd rather not pay if they're too thin.
Thanks.
Personally I don't think they're too thin. The skid plates are at least 1/8" - 3/16" thick steel.
As far as maitenance - you need to mark and cut where the oil drain plug is if you want to eliminate the mess. My skid plate gets in the way as the oil drains out. Other than that I don't have a problem with them. I guess I could use a modified plastic jug to direct the flow, but I like just pulling the plug and walking away for a minute or two while it drains out.
I agree. They seem OK for light duty stuff, except for the plastic piece from the bumper back to the main plate. I've scuffed mine up a bit - especially with the IFS being prone to bottoming out - but they have held up. The one thing I wish they included, however, is a gas tank skid...These trucks don't have the best clearance and that tank is pretty exposed to sharp rocks, etc. It's probably OK (don't think I met anyone who has toasted a tank yet) but I would feel more comfortable if I had it.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
