ATTN MERVZ!!!!
siume99
Mervz,
I can't vote on any polls for some reason.  Any Ideas??  I used to be able too, then all of the sudden no.
Am I being punished ?? :thumbs:
For some reason, the polls, stopped working....  ???
I'll have SiiLT look at it tomorrow...
Guest SiiLT_old
Chevy, what error do you get when you try to pm.  Explain when it happens, etc.
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, [email protected] and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Apache/1.3.20 Server at gm-trucks.com Port 80
That's the message that I get and I've tried from a few different computers w/ the same results.  It does it whenever I try to get into the inbox.  It will say that I have a message on I guess what I would call the messenger home page and who it's from, but if I try to access it, I'll get the error.  Same thing if I try to get in the sent items folder.
Guest SiiLT_old
Good news, i got it to work!!!!!
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
