Hey all, I am at a loss. My Z71 4x4 is lowered on spindles with the torsion set fairly low and 22inch wheels and I keep wearing out idler arms. Like, every 2 months a new idler is needed. The symptoms are a death wobble at 60mph. New idler, it goes away. Comes back in 2 months. All front suspension is new from shocks and bushings, etc. Has anyone encountered this? Thx
If you want my opinion on it, it's those heavy wheels and tires you have.
Coming from my days working in a shop it really didn't matter what part was used sometimes. Customer vehicles that were lowered or lifted would wear the suspension out very quickly. Maybe not every 2 months but within 10-20k were we seeing parts start to show wear again.
The 2WD guys have less problems because they use a regular steering rack. Yours looks like a 4/6 drop and with driveline angles and heavy rims, I think that is why the front end is not happy.
That is just my best guess at what is happening. I'd raise the front up some or try wheels that don't weight 90lbs each.
    • I just brought home a 2020 GMC 1500 Denali.  She has 53K miles on her and I want to change out the fluids over the next few weeks.  I see the diff covers don't have drain plugs.  Any suggestions where I can pick up front and rear diff covers with drain plugs?   Thanks,   Bob
    • Well, the dealership got the compressor and installed it. Air at the vents seems nice and cold as it should be. The service manager said the repair has a two year warranty and unlimited mileage. Hopefully I don't have to use it. The dealership i went to was one where I bought my 2014 half ton silverado. In 10 years and 168k miles on the truck anything I needed done and two small recalls they were always very good to me. Not a huge dealer either. I think they treat people well because they want you to come back. I have dealt with a different dealer that was too big to care about an individual. Just my two cents.
    • Hi All, I operate my 2021 3500 SLT most of the time with the tailgate off and in a crate because I have a slide-in camper. However, at least once a year, I take the camper off and put the tailgate back on. Recently I installed the tailgate, but had a hard time getting the connector bail to swing to the fully latched position. The connector seems to fully seat, and everything works, but the bail doesn’t swing to fully latched position.  It swings almost there but stops and I am afraid to push it any harder.    Does anyone have any advice on cleaning or lubrication or anything else I should be doing?  i know how to properly operate the connector. During the time the tailgate and connector are off, i have a double plastic bag over the truck connector secured with rubber bands to keep it clean, but it still had some dust in it this time when I blew it out with compressed air. I didn’t want to spray it with anything other than air without doing some research. Thanks.
    • There are a lot of spammer's that do that, quote something and add some commentary to make it seem legit, but modify the quoted text a bunch making sure when posted it's long enough to be "click to expand", and either immediately insert a spam link, or come back after some time and edit it to add the spam link.
    • Hello @jaszr2 Do you have a link for the item? I put a replacement bumper on my truck and consequently had to relocate the shutters. I studied on them a while, and figured if you left a couple key blades, you could get most of the airflow with probably no throwing codes.
