My truck has bees showing this error code and only 4000 miles “Service Driver Assist system” need to Dealership twice for this problem, and they don’t know the fix.  It still under warranty. Awaiting a fix.
Our team would like to learn more about your concerns and connect with your dealership to determine the next steps. We can be reached via email at [email protected], and we ask that you provide your VIN, mileage, and dealerships name and address. We are looking out for this. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement: https://www.gm.com/privacy-statement.
