Just wondering if 77.98 hub rings will work? I know it calls for 78.1 but I have some hub rings that came with the wheels and it'd be nice if I could use them.
Edited by M1ck3y
Honestly, yeah they will work. If they are a little snug just use some sand paper on the rings to file them down a tiny bit to make the opening larger.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,029 Guests (See full list)
