Picked this up from marketplace at price that made it ok to try. Not feeling it, if anyone in the southwest Fl area might be interested send me a message. It's a 100r with roof rack in black for 20+ hd with 6'7" bed.20250512_154341.thumb.jpg.baff2b03638c2d6353a8a605630a60ea.jpg
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,427 Guests (See full list)
