Would an aluminum intake manifold heat soak and effect power?
I ask because I’m considering BTR’s truck intake manifold. It loses maybe 40 ft lbs in the mid range but gains 60 plus horsepower/torque up top out to 7000.
Anything metal will heatsoak, no way around that. Only way to cool the intake charge is with a intercooler or heat exchanger of some sort.
Ask yourself this though, how often are you riding that 5,000-7,000rpm rev range? Probably not very often, losing that 40ft/lbs is a lot in that 2,500-5,000rpm section, to me that's not worth it. Adding a camshaft to the engine that suits the proper torque converter would be a better idea to me.
I am adding a btr 220 cam. And your right I spend very little time at peak rpm. But I’m looking for full throttle power.
I don't that that adding a camshaft is going to give up 40-60hp throughout the rev range if not more. The stock truck intakes are really good for torque.
No, the camshaft doesn’t give up much, if any in the mid range. But the Btr truck intake manifold does.
Heres an example on an L8T. The third intake manifold in the graph is a short runner design and it gives up even more in the mid range.
12 hours ago, M1ck3y said:
The cam does give up a bit below 2500…
I have that cam in my 2018. BTR makes quality stuff. With headers it added +100 hp and +80 torque. I don't notice the tiny loss of torque below 2500. After 2500 it takes off like a rocket. The idle chop sounds so good. Been trouble free for 30k km
Was that with e85 too? What Catback are you running? I need to change mine from Corsa Sport; its just too loud with headers.
Edited by M1ck3y
No, tuned for 91. E85 is hard to find here, only one station in the whole city has it.
I have full custom exhaust. 1-3/4” Kooks headers, kooks y-pipe with high flow cats then it duals into 2.5” pipes with Dynomax mufflers. Loud AF. I’ve heard that the Magnaflow 12909 muffles headers good.
This is the dyno sheet. They said it was a 4th gear pull, and it would have 5-7% more power if it was done in 6th.
yesh I was thinking I’d try magnaflow out. They have a single exit 4” with two mufflers.
Nice numbers. I’m getting my work done at the same place!
They are good. If you can afford it, get an aftermarket converter with a slightly higher stall than stock. The only issue I have is when I’m coming to a stop the cam will push through the brakes. Not every time, but it’s pretty sketchy on a slippery snow day
Yikes, I didn't think this cam was that aggressive. Looks like I'll have to be quick on shifting to neutral. Converter isn't in the cards.
Do you know why Davenport didnt dyno in 6th? my under standing is the driveshaft is good until 125ish, was it your tires?
Edited by M1ck3y
I've read that the air is moving so fast through the intake that it doesn't really have time to absorb any heat before it enters the cylinder. Is that true? I'm also wondering if you have any real world experience with an aluminum intake; did you notice higher iat's over a plastic one?
Edited by M1ck3y
It’s not very often, maybe once a month if the tranny downshifts funny. It’ll do one lurch forward. I just mash the brakes harder, lol.
In 6th gear at 6100 RPM I’ll probably be going 180-200 Km/hr. The driveshaft might handle that RPM but the tires are not rated. Just safer for them to dyno it in 4th and do the math after.
makes sense. I just used a calculator to figure out the rpm vs speed. Looks like I’ll have to do a 3rd gear run with my heavy LT tires…
    DM22
    DM22
  • Who's Online   4 Members, 0 Anonymous, 1,694 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
