My truck’s in the shop for a suspected clogged DEF injector. Had the “service emission system,” “reduced engine power” messages along with no power.
I’m shocked there’s no filter on the DEF system to prevent the injector from clogging. Does anyone know of a way to add an inline filter to prevent this issue?
No, I’m not interested in paying $3k to do a full delete. Simply want to improve upon the stock setup.
unless your getting dirt or other contaniments in when filling, there is no need for a filter. the def fluid will crystalize and plug the injector. one way to help prevent this is to always check the date on the def fluid, if its been sitting on a shelf for a year don't use it. also don't use a jug that has been opened and sat for awhile
Clogged def injector is probably crystalized def.
If so, not can easily be corrected by soaking/washing the injecter with water.
    White.6.2
    White.6.2
  • Who's Online   3 Members, 0 Anonymous, 672 Guests (See full list)
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
    • The TCM has to be flashed before it can drive.   If you installed it the way it is, it has the OS (operating system/program) from the 2010 truck you got it from. That will not match with the VIN/OS pair that your 2013 truck has.   You can do the full install. Then tow it to a dealership and they can flash the trucks PCM/TCM with the latest program for your VIN.
