Need your help here, I am tired to see the notification saying  that if i want to use the normal cruise control, not the adaptative one that i have to hold the cruise button. This stupid message is shown each and everytime i press + or- . I couldnt find a way in the truck parameter or the owner manual  to turn off this message, do you know how ?
