Now's the time to build up those rewards for that large order in the spring.
For a limited time, Preferred Customers earn double rewards (two $5-Back rewards in the U.S./5%-Back coupons in Canada) on orders of $100 or more. The promotion runs Nov. 5-18, 2025. Double rewards will be added to their MyRewards page Dec. 4, 2025. Rewards expire June 2, 2026. There is no promo code for this offer.
Apply to be a Preferred Customer here.  ➡️ https://www.amsoil.com/offers/pc/?zo=521390
  • txab pinned this topic
  • txab unpinned this topic
