I have a 2019 GMC Sierra 1500 SLT with 42,311 miles. I started hearing a humming sound during acceleration starting at 45 mph. I took my truck to the GMC dealership. The diagnosis was that I need a rear differential rebuild. July 28, 2025, I had a rear pinion seal that was replaced because of differential fluid leaking and engine oil cooler lines replaced. I have a warranty with Ally Premier Protection  Major Guard Policy. I dropped my truck of January 13, 2026 (Tuesday night). As of today, January 22, 2026, my differential claim with Ally hasn't been approved. The latest update this morning from my GMC service advisor was that Ally emailed and wanted to know if GMC could get  a complete rear axle. GMC doesn't offer complete rear axles, they just rebuild them. My truck has been grounded for 9 days, and I still don't have an approval for the claim or a rental car. Has anyone else had to deal with a 2019 GMC Sierra 1500 SLT warranty repair that has moved this slow and taken so long? Frustrated doesn't begin to explain how I feel about this process.
That's not unusual for a service plan.  They love the up front money, but when it comes to paying for repairs...delay and deny are the first things out of the blocks...
Be careful, service plans will sometimes approve the replacement of the damaged component with a used, but in good condition component if its cheaper than the repair of the original component.  I had a radiator replaced that way without my knowledge until it was too late.  In your case, it would probably be cheaper for the service provider to purchase a used rear end from a salvage yard than to pay the dealer for the rebuild of the one you have.  Be wary, trust but verify.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
