Just got my first truck, a 2006 Silveado 1500 with the 5.3, and I've got all the issues chased down now except for these last few...
The first is a P0455 error code, which is a leak somewhere in the evap system. My gas cap is new and down tight, so the next part I'm trying to look at is my vent valve/solenoid, which should be right next to the charcoal canister and tank. I think I've found it based on location, but what I'm seeing on my truck isn't matching either the videos or the parts I'm finding on rockauto. The only potentially cannister-like or vent-valve-like parts I've found next to the gas tank are what's in my picture here. These are right next to the front side of the tank, and have the same type of hoses running to them like I've seen in the videos, but aren't shaped nearly the same. Is this my canister and vent valve part I'm looking for?...
Canister and vent valve?
The second issue is the leak I'm seeing coming from my rear differential. It's at the front of the diff where the drive shaft ties in. How hard is it to change this seal? Any general advice here?...
Rear diff
And last is this rubber hose I found that terminates on top of the crank case. I was able to feel above the transmission and trace it as it runs toward the engine. It has some kind of Y branch in it just on top of the transmission, and continues forward further than I could feel. Just making sure this is some kind of vent hose that I don't need to worry about. The truck had some transmission work done just before I bought it, and I've already found some screw-ups when it was being put back together.
I'm all ears.  Thanks
Usually the vent valve is on the front of the gas tank or right above it in the front of the tank on most chassis I believe. It's a small round one. Your picture is the whole charcoal canister.
Your diff leak is the front pinion seal. Pretty common leak. Remove the driveshaft and there will be a large nut holding the diff yoke on. Probably a 30 something millimeter socket for that. Once the yoke is off you can remove the seal. Watching a youtube video would be helpful. I always mark the nut before removal so it goes back on pretty close to the exact spot to keep everything good. I even count the exposed threads to make sure it's the same. A good impact gun does the job for me. It's not exactly the correct way to do it but nobody does it by the book when just replacing the seal.
The hose is the vent line for the transmission and probably the transfer case too.
transfer case has a different tube, that goes up to the top of the transmission with a small filter cap (goes to the same bracket that other hose for the trans vent goes to).
    jrogjr
    jrogjr
  • Who's Online   1 Member, 0 Anonymous, 348 Guests (See full list)
    • Average Assembly 4.8%   That's the likelihood of a light duty vehicle reaching 250,000 miles. Link below has the stats on this. Among pickups the 350 series (Dodge)  and higher (450 Ford) are most likely and nothing American built in the lighter trucks pegs a number higher than the overall average.  200K and up is the stomping grounds of Asian vehicles. Toyota Sequoia the leader at 39.1% probability.      https://www.autoweek.com/news/a68886903/vehicles-most-likely-to-last-over-250000-miles/   Likelihood drops dramatically at 100,000 miles of reaching even 150,000 miles. 250,000 is deep in the tail of the curve.    I've been told by the 'experts' that I don't need oils of the caliber I use. My high viscosity is damaging my motors. Ash content it to high and WILL foul plugs and kill cats and O2's. I don't need that much ZDP; my choice is over added and not cutting edge. I change it to often. I baby them to much.    Three Honda's reached 200K + and none used oil. All Red Line motors. All sold to friends or family. One Toyota reached 300K using oil, Pennzoil. Dizzy 300K using QSUD until it cashed the rings at 80K then whatever but often ever since. Did you know this engine still sports the OEM timing chain and is dead silent? Pepper spitting into the wind short of 200K, Red Line and changed often. Uses zero oil. A HPFP and a pinion seal. Still using most parts it left Fort Wayne with. So 50% of my vehicles have gone past 250K and 100% of the last half dozen past 200K. Of these two using "shelf oils' did so using abnormal oil and the four that used a premium boutique oil did not. There might be something there the experts have missed. 🤔
    • i dont know where you been reading...they make a top notch product..people say lots of great things about them..yes it can be difficult to get a hold of them when you need help sometimes put when  you do it is great service...   as for the actual question at hand i have the ccv mod and i vented to atmos in my case...I got my ccv from somewhere else but i have plenty of VSE product...for starters i use their tuning on my 22 duramax
    • It's not that it sits for extended periods. I drive it every couple of weeks. However, I did consider draining the DEF and replacing it.    Don't you get a "Poor quality DEF warning" if its bad?
    • Try draining the def and relacing with new if it has been sitting for a long time. Def does go bad after a little while.
    • Thanks @Viktorrocks15 if you are still out there.   I followed your instructions and worked out great, went to the scrap yard and procured 2016 escalade cluster, hud, bezel, and switch. Got lucky and found a Camaro in the u-pull with the HUD bezel.   I made my own harness with these diagrams: https://www.gmupfitter.com/wp-content/uploads/2022/10/23_Escalade_Escalade_ESV_Electrical_Body_Builder_SM_en_US_2022OCT25.pdf   I used escalade cluster because its the best one that will work IMO. Still need to get it programmed but it looks really good.
