I was pretty sure I read somewhere that GM's bi-directional charging can only be used with their proprietary charging system but can't find a definitive source. The Ultium cars (or whatever GM is calling them now) will do it, it's just a matter of if you can use a non-OE system to use the feature.
Contacting Sigenergy might also provide you a good answer. The EV forums here are pretty quiet...
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 285 Guests (See full list)
