94 Silverado 350
When I apply the brakes, the rpms drop. In park or neutral the drop is approx 150 rpms and in reverse or drive approx 250 rpms. When I release the brake, the rpms go back up to normal.
I installed a new booster (rebuilt) last august 2025. Didn't have any problems until a couple of weeks ago. When I was working on the throttle body issues last month, I noticed some leaking around the booster vacuum line, so I replaced it. I have gone back and re-tightened the hose clamps and don't hear or see and leaks.
I don't think the booster itself is leaking internally. The brake feels like normal and it stops ok. The pedal doesn't go to the floor, and I don't hear any hissing. When the truck is off, I still have pressure, so I guess the check valve is, ok?
I do question the rubber check valve grommet. Maybe its leaking around it? The replacement hose was just a section of new hose.  I plan to check it some more and test the check valve.
When I rebuilt the throttle body, I did replace the idle air control valve with another one I had. It was almost new, so I don't think that is a problem.
Any other ideas or test suggestions.
Thanks
maybe just plug the vacuum line to the booster, to rule out that path as being the cause of the rpm change?
I can do that.  When I pull the check valve off, I will plug the line going to the intake.
I did plug the vacuum line and the rpms where ok.  I also tighten the booster line going into the intake. It was a bit loose and that didn't make a difference.
The booster probably failed internally. (Applying the brakes is basically creating a vacuum leak.)
I think you are right the brake booster must be leaking internally. I have tried everything else. Yesterday I replaced the check valve thinking it maybe wasn't closing all the way. Didn't really believe it since the booster held vacuum when the truck was off.  I even bought an original gm check valve from Rockauto.
That booster isn't even a year old. O'Reilly's lifetime warranty.
I am not looking forward to removing/installing that brake pedal clip again.
Good news is that my truck is running great after the throttle body re-built issues.
Thanks for the support.
Everything's always easier the second time!
It took me less than 5 minutes to remove the brake pedal clip. It is easier when you know how to do something.
Waiting on the replacement booster. Hopefully it will arrive sometime today.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
