94 Silverado 350
When I apply the brakes, the rpms drop. In park or neutral the drop is approx 150 rpms and in reverse or drive approx 250 rpms. When I release the brake, the rpms go back up to normal.
I installed a new booster (rebuilt) last august 2025. Didn't have any problems until a couple of weeks ago. When I was working on the throttle body issues last month, I noticed some leaking around the booster vacuum line, so I replaced it. I have gone back and re-tightened the hose clamps and don't hear or see and leaks.
I don't think the booster itself is leaking internally. The brake feels like normal and it stops ok. The pedal doesn't go to the floor, and I don't hear any hissing. When the truck is off, I still have pressure, so I guess the check valve is, ok?
I do question the rubber check valve grommet. Maybe its leaking around it? The replacement hose was just a section of new hose.  I plan to check it some more and test the check valve.
When I rebuilt the throttle body, I did replace the idle air control valve with another one I had. It was almost new, so I don't think that is a problem.
Any other ideas or test suggestions.
Thanks
maybe just plug the vacuum line to the booster, to rule out that path as being the cause of the rpm change?
I can do that.  When I pull the check valve off, I will plug the line going to the intake.
I did plug the vacuum line and the rpms where ok.  I also tighten the booster line going into the intake. It was a bit loose and that didn't make a difference.
The booster probably failed internally. (Applying the brakes is basically creating a vacuum leak.)
I think you are right the brake booster must be leaking internally. I have tried everything else. Yesterday I replaced the check valve thinking it maybe wasn't closing all the way. Didn't really believe it since the booster held vacuum when the truck was off.  I even bought an original gm check valve from Rockauto.
That booster isn't even a year old. O'Reilly's lifetime warranty.
I am not looking forward to removing/installing that brake pedal clip again.
Good news is that my truck is running great after the throttle body re-built issues.
Thanks for the support.
Everything's always easier the second time!
It took me less than 5 minutes to remove the brake pedal clip. It is easier when you know how to do something.
Waiting on the replacement booster. Hopefully it will arrive sometime today.
