I have no display of  transmission  status on Dash  ( no P,R,R D or L) a code has been set  as i now  have  a Check engine light,  Als  "SERVICE STABIL TRAC " is  displayed on  the Info  screen. The  truck drives but  fro  engine RPM it  seems  to be in LOW gear
 Any Ideas ???
Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
  • Haha 1
get a good code reader, and find out what problems the truck has noticed by reading codes.
cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,492 Guests (See full list)
    • I have 2 choices.
