Looking for advice from this group. Took my flawless 2020 6.2 TB to an unnamed shop for routine rear brakes and oil change. Tech forgot to put oil back in after the full service and needles to say, destroyed my engine.  It’s all on their shop video so they are responsible.
I had my Chevy dealer do the analysis and they confirmed its compromised and said engine replacement. The manager said they only get GM reman engines from GM with full 3 yr warranty and the one they would put in is not same as what’s they are swapping out on 21-25 for recall.
I am looking for advice why that would be a different engine because obviously I had the good 6.2 year and replacing it has my concerns with that recall for 21-15
Also what’s the pros and cons of accepting the engine swap vs telling the shop that bricked the truck to pay up so I buy a new truck. I’m concerned about stigma resale eventually if I just decide to get rid of it after the swap or other issues showing up after the swap out.
Edited by 2017Z
Spelling
Correct.  2019-2021 model years are serviced by a different p/n.  19420611.  Recall 2021s use 19420611.
The recall engines 2022-2024 model years are serviced with 12740076.
The difference between 19420611 and 12740076 is GM changed injector size for 2022.  The injectors are smaller on 12740076 with smaller injector bores in the cylinder heads to match the smaller injectors.  So you can't install a 19420611 in a 2022-2024, and you can't install a 12740076 in a 2019-2021.
Both engines are the replacement engine p/ns that are in the L87 recall.  So both of these are the updated engines.
Here's a version of the L87 recall with the p/ns for all the parts needed.
RCRIT-25V274-7075.pdf
Note it shows 19420611 and 12740076 with an asterisk to a footnote "Use the VIN and the GM Electronic Parts Catalog (EPC) to determine which part to order if two or more part numbers are listed for the same part, as it may vary by vehicle options."
Edited by newdude
Thank you. Any advice or comments on my concerns of doing the engine swap?  Dealership is doing it so feel semi ok.
or any issues with the remand for this year having the parts that are causing the current recall ?
Edited by 2017Z
Add
Probably not their first rodeo, so it should go as planned most likely.  Typically the service manager or tech doing the swap will put some seat time to shake it down after they get it all put back together.  We usually put 50-100mi before we hand them back so if something happens, its not after you get it.  A coolant leaks, oil leaks, a ground left off or loose, vibration, etc.
The new engines so far have been good?  There's been a couple that have popped out there again (the replacement engine) but most have been okay.
Edited by newdude
    DLZ
    DLZ
  • Who's Online   2 Members, 0 Anonymous, 505 Guests (See full list)
