Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
9 hours ago, richard wysong said:
Looks like it's riveted to me. What is wrong with that 1? Welcome to the Forum!
No, it is a screw with a nut holding that on. That is my friends truck. First photo is from online.
Edited by B07
14 hours ago, davester said:
hit a junkyard.
They will only sell the complete system. They don't let you pick things apart. $5 part or sell the whole thing for $150? Which do you think they want?
Edited by B07
Year/make/model/engine??????????????
From the looks of the piece you need, pushes into the airbox and then the big loop clips around the radiator hose?
If you have a u-pull-it yard you could get just that piece and not the whole tube.
Edited by newdude
1 hour ago, newdude said:
2007.5 NNBS Silverado 1500 5.3. If you look at the photo it attaches to the air tube. You can see that half shaped disc is molded into the side of the tube and the piece that the hose clamp snaps into is screwed down to that with a screw and nut.
We don't have pick and pulls here and the nearest wrecking yard is 80 miles away. They sell everything as complete pieces. Need a door panel piece? They'll only see the whole door panel. This place caters more to body shops.
Do any of y'all have the original air box system on their truck? If so lift the hood and you'll see what I'm seeing.
Edited by B07
48 minutes ago, B07 said:
One of these?  GM # is 15041307.
2007-2014 GM Multi-Purpose Clip 15041307 | QuirkParts
Or.  For some reason a couple years they show this on only the little hose to that duct spot.  15041309:
ACDelco 15041309 ACDelco GM Genuine Parts Clips and Multi-Purpose Retainers  | Summit Racing
I have the first one. That snaps into the piece mounted to the air tube. Look at the 3rd photo and you'll see the tab pushed into the hole that mounts to that other piece. Hard to see but that piece circled is help on by a screw and a nut. The bottom part has a whole drilled in it for the tab on the hose clamp to snap into. I'm assuming you all have CAI's?
Edited by B07
These are the other two I see listed.
15159494
15159494 - Genuine GM Clip, Radiator Inlet Hose
15045503
15045503 - Genuine GM Clip, Radiator Inlet Hose *Black T
22 minutes ago, B07 said:
If you need that mount looking piece.  You need the air tube.
Cheapest one I see on eBay - 2007-2014 GM Silverado 1500 Air Cleaner Outlet Duct Assembly 5.3L OEM 15901934 | eBay
Same price but free shipping - 2009-2014 CADILLAC ESCALADE 6.2L AIR CLEANER OUTLET DUCT ASSEMBLY 15901934 OEM | eBay
Edited by newdude
Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut.
Been all over eBay.
I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
Been all over eBay.
Just buy the tube and move on with life.
  • Haha 1
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
