Can Onstar be used for a GPS???
Even if you don't subscribe???? I mean they know exactly where you are positioned sho there has to be a GPS antenna somewhere in the truck...
A GPS system just receives... So can I hook a lapptop to it somehow?? hmmmm
I know I am nuts.. I have the Onstar but never subscribed... Trying to find alternative uses....
Even if you havent subscribed after the first year the Onstar still works if you get in an accident and your airbags deploy. Tampering with the Onstar will exclude you from any warrenty left on your vehicle. Also the radio & Onstar work together on 2003 and later vehicles. :confused:
It's a simple mod.. this will not affect the normal operation..
It simply brings the serial interface to the outside world so you can attach a laptop pc.. ;)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
