help !!  ABS Motor noise
Kingclever
Hey guys, I need help. I have a 1999 5.3 Silverado and I noticed my ABS light came on today and my ABS motor under the frame is making lots of noise. I unplugged it. Does anyone have a motor for sale? Also, once I replace it, I'm sure I need to extensively bleed my brakes, unless someone else had this happen and knows of anything else I need to do instead.
[email protected]
It's a problem with GM trucks in general, not just Silverado's that utilize the Kelsey Hayes modulator.  There is a TSB (don't know it on the tip of my brain) but before going and replacing stuff, make sure a wheel speed sensor's and/or it's reluctor isn't the culprit first.  This too is common on the full size  trucks which will engage the ABS at slow speeds when braking.
Plug the motor back in and unplug the fuse underhood.
The previous owner unplugged my motor, and the positive terminal in the connector rotted out.
You'll need a new ABS computer, and it's not cheap.  If it's under warranty, take it in.  Otherwise, you're SOL.  I think it costs $850+ out of pocket to get it replaced.
I've just been living without ABS!!!
Oh yeah, you can replace it yourself IF you can get the ABS computer off of the ABS unit.  Most people can't, and have to pull the whole assembly.  If you do that, then you DO have to bleed the brakes and also have your truck towed to a dealer so they can charge you $60+ to hook it up to a Tech2 tool to invoke a special bleed procedure in the modulator unit.
Kingclever,
I just finished down the same path as you w/ my '99 5.3.  I also assumed that you'd need to replace the entire unit, not just the motor assembly, so I thought the brakes will need to be bled.  If it's truly the motor (and not the sensors, as CMNT pointed out above), the brakes will not need to be bled.
My motor ran even after shutting off the engine - I had to pull the fuse block under the hood (look inthe manual - it's one of those gray OMRON blocks) to shut the noise off.
My dealer said it's $950 list cost to replace the unit - I managed to sweet talk them down by levelling with them asking for help, and to their credit they did help considerably.
Here's the topic I started about this if you want to read all the details!  This may not be the only topic here as it seems to be an issue with any vehicle with the Kelsey-Hayes units.
ABS Control Module Topic
Good luck and keep us posted!   :P  :P
:P  O.k. gus, I have replaced the unit and that was the problem. I called to several placed and prices ranged from 798.00 to 386.00 on a website. The website price was very cheap, I think it was gmpartsdirect.com...but they hit you very hard on shipping 80.00 roughly. Well, I was able to work with a local dealer and he was able lower the price to 500.00 and he had it in stock. Replacing it was a breeze. Took me about 20 minutes with basically a small torx bit in my 1/4 drive ratchet, pulled off three plugs on the unit and 'voila!
I wiped the solonoids [6] clean and the mating surface and put the new one on. I didn't have to remove anything else. Well, this new ABS control module has a new part number: 88982286, made my Kelsey-Hayes. Suuposedly it is a better built unit. I hope so. Plus I was given a 12/12 warranty on it. Wehn I talked to numverous dealers yesterday, they all commented on how common this part was on failure. Similar to the honda accord ABS module failures of 94-96. Maybe they were made by the same people?...not sure.
Thank you for all your help guys!!  ;)
WOW!  You were lucky!  I haven't done mine yet just because ALL 4 screws stripped!!!!!  I don't even know how I'd get any kind of tool in there to grind off the screw heads without pulling the entire assembly.
Can I have your old module for investigative purposes?
    • 3.59 Kroger’s in Montgomery Tx. 20 cents higher than most around here. Very unusual. Saturday they were 3.49.
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
    • Yesterday a suggested youtube video thumbnail caught my attention so I watched through it and it was a bunch of short clips someone gathered together of people pulling trailers, a lot of them were bumper pull holiday trailers and a pickup or suv pulling it. a few fifth wheels as well, some motorhome crashes also. The tail wagging the dog theme was quite evident in numerous self inflicted accidents that took out vehicles around them sometimes in the process as the unit finally swung around and flipped over in the middle of the highway. Or the other classic which literally could be called "I forgot the trailer was back there" in passing another vehicle on a multi lane one way freeway and then cutting back in line before the back of the rv trailer had passed the front of the passed vehicle and often in front of a tractor trailer and that never ended well. Or the wide kick out swing of the rear of a long travel trailer as they have so much overhang behind the axles and the trailer smashes into the side of vehicles in the next lane over ( typically sharp turns in city driving ). It makes one leery for good reason to be near an RV trailer after watching a video like that and be it on the highway, in town, or at a gas station where that rear end comes swinging around due to the fuel station being so cramped and not intended for larger trailers. I wonder how many officers have heard those words though "I forgot it was back there" as they investigate the accident LOL.
    • $5.10 for regular at the Kroger   It's been 6 months... is this the "new normal" ?
    • Just because a person can buy a travel trailer or a motorhome doesn't mean they can drive it properly. My observation during my RVing years.
