'Performance' mufflers
I thought the muffler made a difference in the rumble when installing a catback dual exhaust, but it's the large tips that made a difference on my truck. When I cut off the 24" long, 3" diameter chrome tips in favor of a smaller diameter, side discharge pair the rumble disappeared. I had to install another set of wider diameter tips to get the sound back. Why buy a 'performance muffler' when you can just add tips?
Good Question, I was thinking about replacing my 4" tip but now I will wait to see what the concensus is here. I was going to go with stainless steel instead of chrome. I have a flowmaster on and really like the sound right now so I dont want that to change.
Also, there are tips that appear to have a double wall. How do those affect the sound of the exhaust?
"wortec's" are a Flowmaster knockoff, don't sound exactly the same, but same characteristics of sound.
I'm not too great with tips, but yes, tips make a difference. A larger diameter tip that's also quite long makes more of an echo sound. A smaller tip hooked to a smaller pipe size will make a quieter sound, less rumble, a little more refined. The muffler IS what ad's that true performance sound, the tips just sorta kinda ad to it.
Doiuble wall tips are basicaly what they say I gues, double walled. They do make resonaed tips that help cut sound down some, seem to help I guess
Oh yeah, go stainless BC! It lasts longer and if you keep them shiny they look d**n good. I painted the inside of my tip black (Carefully masked off around the very outer edge and all around the truck so I wouldn't overspray the truck lol. I did it a little over a yr ago, and it still looks black as it did the day I painted it! No rust!0 That's the only other way to keep Chrome tips lasting longer.
My Vortex muffler sounded no different than the OEM without the tips. My tips were installed last week and have already rusted inside. I liked the idea bout black paint - is it too late to paint and if not, what prep do you suggest?
Nah, it's not too late to paint. I've had exhaust for about 2 years now, and I did it about 8-9 mths after mine was installed. All i did was take a scotch-brite pad, cleaned the surface inside somewhat, and then just masked the tip off and then covered areas where it was possible to get overspray. I let the truck idle for about 20 min. just since I wasn't sure if it would hold, but it's help fine so far. The rust on your is prolly just surface rust from condensation build up. When I have my exhaust redone eventually I'm having stainless tips installed instead of Chrome
I thought Vortec was just a Flowmaster knock-off, I gues I'm thinking of another brand. Just go with a new muffler to get that performance sound back.
