Garmin iQue3600
cdubb
I swear now that you can get in car navigation on a 20k Mazda 3 I bet the market will get very competitive in terms of GPS. I prefer my Garmin iQue 3600 that I got at RadioShack. I can take it everywhere with me and it fits perfect in my Envoy. Why pay 2k extra for GPS when you can buy a portable one for $550.
The Garmin iQue3600 is definitely the best bargain for a rookie GPS driver that wants versatility and convenience. RadioShack carries them and they are on sell for $550. It’s a big purchase, but it is a PDA/GPS & MP3 Player all in one!!! This thing is awesome and the guys at RadioShack were the best. It’s so fun and easy to use. Turn by turn voice guided directions. It’s easy to justify spending that much when you think about how much a PDA, GPS, & Mp3 player would cost separately. Plus, it has Palm OS so it’s a proven product. Garmin is highly recognizable as the leader in the industry. RadioShack has lots of cool GPS products from Garmin and Magellan. They have the Roadmate on the web with a really cool demo. Go to RadioShack and buy an iQue3600, you won’t be disappointed. thoughts???
No, I dont work at RS, i just think they know thier stuff!!!
We do appreciate your input, but once again.... That wasn't very nice. :sigh:
If you have an issue with the site, take it up with a mod, or site admin.
-Wingnut
well, i speak the truth. C'mon, It wasnt that bad, maybe if I cursed about fords/dodges my posts wouldnt be deleted. down with censorship. i drive a gmc, hear me out.
I tried to get a GPS/Navi forum started and no one was interested, I thought this was the place to be for informative product reviews/discussions. I guess I am lost. :cheers:
