Squeaky wipers
What is the best lube product to put on the wipers if they squeak. Would it be something like white grease or silicone grease or as simple as WD-40....
Whats sqeek'n? The linkage or the blades?.....If its the blades,get new 1s,or try clean'n them w/rubbin alcohol...If its the linkage,a small amount of chassis grease in the sockets should do.
Its not the blades.
Its the linkage I believe.
I just wasn't sure if there was something specific for it. Its like when your doors squeak you put on Lithium grease which is the best for that....
I guess white lithium would work,but I found that it gets washed away faster when exposed to water constantly. It may require more frequent applications...just my opinion :thumbs:
